Posted by JimB2 on March 25, 2010 at 19:39:19 from (208.94.30.106):
In Reply to: Hydro 83 project posted by downeast maine on March 25, 2010 at 16:08:16:
Hi DE, the Hydro 84 is the same tractor as 784 except for drive train. It has a German D-246 Diesel engine. Re electrical, hopefully it has Delco not Lucas electrical system, there are a couple of connectors that give problems, one is under rear of seat and there is a ground lug that connects to seat platform that supplies ground to several of the circuits. Some tractors also have another connector under the battery box. Re Brakes, yes require bleeding, check archives for 674,684,784,584 brake bleeding method. Re PTO, PTO lever linkage will be siezed up, use your favourite penetrating oil and lube everything. Under the left foot rest will be the MCV valve and hydraulic filter. The PTO actuator is under the rubber boot on top right of MCV. You may have to pry boot up and squirt penetrating oil in actuator under the boot.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
