The idea is that the old distillate fuel was pretty low grade and about impossible to start a cold motor with. You started the tractor and gas and ran it that way for a while. Once warm woul would swithc over to distillate. Between runs you had two choices. You could switch it back to gas for the last few minutes of running so that the bowl was full of gas for the next startup. The other would be if you shut it down without switching over, the dual fuel carbs typically had a drain valve on the bowl, so that you could drain out the remaining distillate and let gas down into the bowl to get it started.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
