If yours is lost, it will require two measurements, one to determine its diameter (measuring carefully with an expanding gauge, then measured with a good micrometer), The depth into both holes that a dowel can go into is also needed. The dowel should be a locational fit. This means it should be able to be tapped in easily, but not driven in. A careful center ground pin (machine shop) will do it. The numbers should be exactly the same measured diameter, or .0005 interference. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
