Re: Farmall 400 Hydaulics
Posted by Matt Weltz on March 27, 2010 at 19:30:02 from (208.126.16.132):
In Reply to: Re: Farmall 400 Hydaulics posted by Janicholson on March 27, 2010 at 09:26:50:
Played with the lever for a while again this afternoon. Still no luck. Also tried changing the valves back and forth between dual and single-acting. Like I said, the engine is not bogging down when the levers are moved forward/reverse like there is either no fluid moving to the valves or no pressure. What else can I try or check? Thanks!
