Posted by rustyfarmall on March 28, 2010 at 05:48:32 from (209.152.78.140):
In Reply to: headlights posted by mike paulson on March 28, 2010 at 02:13:48:
mike paulson said: (quoted from post at 02:13:48 03/28/10) hey Kirk, can i used 6v lights and just replace with 12v bulbs if i ever do switch to a 12v system, the reason i ask is the darn light setups are like 100 bucks for 2 of them....thanks
Yes, those original style, flat-back sealed beam lights are kind of pricey. I would suggest that you make the decision right now to either leave the six volt system in place, or make the change-over to twelve volts BEFORE you buy the lights. Of course, there are generic 6 and 12 volt headlamps available that are priced much, much lower and function just as good, but would never be considered as "correct".
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
