Posted by Formerly PaMike on March 28, 2010 at 08:27:46 from (24.152.202.123):
I have a 656 Utility with the splined rear axle. The hub is worn badly so I have a new hub on order. Does anyone know if you can pull the axle out or do you have to take the whole axle housing off? I have a loader on the tractor so it would be a whole lot easier to just pull the axle than to try and take the whole housing off since the loader is bolted to it. Thanks
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
