Re: 340 c135 main engine bearing replacement
Posted by farmer budd on March 28, 2010 at 10:13:14 from (76.247.153.206):
In Reply to: 340 c135 main engine bearing replacement posted by b peppler on March 28, 2010 at 04:40:46:
you can not replace the rear main easly. the flywheel blocks the bolts to remove therear main seal (split bracket) and i "m telling u that u want to replace this seal in a easy matter, really u want to replace the front one too.the other thing to consider is the crank goes thru the front cover and it"s going to have to be replaced also, consider this if it"s worth doing do it rite.
