Posted by CNKS on March 28, 2010 at 13:53:20 from (216.144.104.128):
In Reply to: Farmall H brake Drums posted by powellcrazy on March 28, 2010 at 13:45:01:
The seals are behind the brake drums covered in crud. They literally have to be dug out. Clean the areas up, drill a hole in the seal housing, insert a screw and try to pull them out. The screw will likely come out. So carefully begin digging them out. Without the proper tools there is no other way. Install new seals with the lip toward the oil. One on each side is probably enough, some install 2 with grease between them, but I doubt if the outside one lasts long.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
