Re: farmall c alternator wireing
Posted by Janicholson on March 28, 2010 at 17:26:49 from (64.61.211.250):
In Reply to: farmall c alternator wireing posted by nl00sb on March 28, 2010 at 17:16:30:
The alternator output wire (big) should go to the amp meter. If the system is now Negative ground, it will need to have the leads reversed on the amp meter. Attach the Wire to the side of the meter not connected to the wire going to the battery cable at the starter switch. If a 3 wire setup, a momentary contact switch is needed in the #1 terminal wire to excite the alternator.(or a hot wire going to a oil pressure switch (normally open switch from NAPA) that allows exciting voltage to #1 terminal.
The #2 terminal goes directly to the big post on the alternator, a 6" wire.
Jim
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
