Interesting. You are lucky it is still working. But the reason it fires is important. Most electronic ignitions will fail promptly, or arc the inside of the coil when allowed to operate with no path for spark to go. (pulling the wire out!) Reason is that the process you describe raises the spark voltage to about 25000 volts or more. As the wire gets into contact this serious voltage will jump the spark plug gaps with more energy and ignite the fuel and air starting the tractor. Fix it by putting in new plugs gapped to .045" and it will be fine. I like Autolite, or Motorcraft plugs. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
