Re: IHC no. 9
Posted by ihcarl66 on March 28, 2010 at 18:27:54 from (207.171.222.52):
In Reply to: Re: IHC no. 9 posted by JD2840 on March 28, 2010 at 18:11:32:
The frame is ih red the cutter bar is blue and the wheels are ih white or yellow. I like the ih white better. The tractor hitch is just the horse tounge sawed off about 3 to 4 feet in front of sickle bar then bolt your two pieces of flat steel to the end of tounge to put the hitch pin in. The horse tounge is 15' long as it sits in the frame back to the axle. I had the Amish saw a tounge out of Ash for $20, the tounge is 5" wide where it mounts in the frame so a 4"x4" won't work. I have seen them made of pipe but wood is better for the vibration of the mower.
