Re: Farmall 400 Hydaulics
Posted by Matt Weltz on March 30, 2010 at 03:06:55 from (216.81.243.237):
In Reply to: Re: Farmall 400 Hydaulics posted by um 5 on March 29, 2010 at 18:34:10:
Had trouble with that screen on my 300 so already checked that and everything else in that regulator block. Main screen in the reservoir was also cleaned. Guess it is just air locked like Jim suggested. Just have to finally get it worked out! Worked the levers back and forth for a while again today with no luck. Finally shut the tractor down becuase the pump was starting to get hot. Hope I can get this worked out soon!
