Re: h shifter?
Posted by sflem849 on March 30, 2010 at 04:13:52 from (69.197.84.192):
In Reply to: h shifter? posted by deltared on March 29, 2010 at 21:21:50:
deltared said: (quoted from post at 21:21:50 03/29/10) Would it be easier to heat it and benb to the desired shape?cheaper?
If they use the same four way hole setup as an H it should work really well. I would guess they just about give away the H shifter handles. There probably isn't too much demand for that part.
