Posted by Nebraska Cowman on March 30, 2010 at 08:03:02 from (66.252.127.216):
In Reply to: h shifter? posted by homebuilt on March 29, 2010 at 17:44:41:
I am pretty sure everything below deck is the same. But finding a lever that's not worn out will be the next thing. You can build them up with a welder and it should look like this.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
