Re: A steering
Posted by Rootsy on March 30, 2010 at 12:23:42 from (24.247.111.162):
In Reply to: A steering posted by Enar on March 30, 2010 at 11:14:26:
Not much you can do by just pulling the long steering wheel shaft / worm gear.
If you have the square pitman arm / shaft connection you can get in there to make sure it is tight from underneath the tractor... Otherwise the front end MUST come off to get the sector gear / shaft out.
The housing splits into two parts and is sealed by a gasket and the shafts by seals.
This post was edited by Rootsy at 12:25:21 03/30/10.
