Posted by CJ_1080 on March 30, 2010 at 16:16:14 from (166.235.72.224):
In Reply to: H pilot bearing posted by jerry hakenwerth on March 30, 2010 at 16:04:12:
What you do is find a piece of steel rod or cut a bolt after the threads so you have a round smooth shaft. Make sure it will slide in the pilot bearing center but still be real close to the diameter. Pump it full of grease till it fills up the center and under the bearing. Take the pin or rod and center it in the hole. Take a hammer and pound it in fast and hard. The quick pressure on the grease will force the bearing out. The grease wont want to compress, and will transmit the force to the bearing. You may have to pump more grease in and hammer again. Hope this helps. Good luck -Corey.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
