If you tried cranking the tractor and it didn't start could explain the gas leaking from the carb - they will do that, especially if you use much choke. As for the belts you don't need a belt on anything to start the tractor - only to keep it running for very long. You have to remove the fan belt to put on a generator belt. The fan pulley has a flange on one side that screws in and out and tightens the fan belt by making the the belt run further out on the pulley. As for the tractor quitting after a few seconds, 2 things I would start with is make sure you have spark and a good continuous flow of gas. A partially plugged line, screen, etc will let you get started, but not enough flow to keep going. Old tractors can have a number of issues with corrosion in tanks and fuel lines.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
