Re: Belts Broke on my H, and it wont start
Posted by El Toro on March 30, 2010 at 17:45:28 from (74.103.74.58):
In Reply to: Belts Broke on my H, and it wont start posted by Faster346 on March 30, 2010 at 15:39:16:
If you have a distributor you need to check for battery voltage at the coil. With the ignition switch on and the points open you should have battery voltage on both small terminals. If you have voltage here pull off one of the plug wires and hold it near a good ground while someone makes an attempt to start the engine. If there's no fire from the plug wire, clean the points.
If there's no voltage at the coil with the ignition switch on, run a separate wire from the battery to the coil, then see if the engine will start. If it starts your switch is bad or there's no voltage being fed to the switch. You will need a volt meter to check it. Hal
PS: If your battery is fully charged your engine should start without the belts installed.
