Re: IH 370 disc in disguise?
Posted by amnion on March 30, 2010 at 20:24:32 from (66.44.160.180):
In Reply to: Re: IH 370 disc in disguise? posted by MirageFlatter on March 30, 2010 at 16:22:25:
Thanks for the responses guys!
Yeah, I noted the JD cylinder when I picked it up. Maybe that is the reason they decided to go with the JD green and yellow!
Was the folding hitch an option on these or is that someone's custom work? Makes the unit nice and square when parking it.
The disc needs a couple of the cane-shaded pins that lock the gangs in place, or a suitable bolt/pin as a substitute. Also have two blades to replace near the outside on the front-right gang. $600 seemed like a nice price though.
I only disc about 10-15 acres of bean stubble per year prior to seeding hay fields so it won't have too tough of a job to do.
