Re: plowing advice needed
Posted by mkirsch on March 31, 2010 at 05:35:09 from (64.80.108.55):
In Reply to: plowing advice needed posted by RJV on March 30, 2010 at 21:58:00:
It sounds like you're plowing "virgin" sod. That's the worst or so I've been told.
Don't be afraid to go at the surface of the moldboard and share with an angle grinder and 40 grit flap disk, then 80, then a 120 grit random orbit sander. Change papers often when you get to the sander. Get it shined up as much as possible before you go plowing.
If you really want to get crazy, you can keep using finer and finer grits until you get to a mirror finish.
When you're done plowing cover the shined surface with a healty coating of grease gun grease (moly or lithium, comes in a tube). It'll be just as shiny come next spring when you go to plow again.
