Re: amp meter question
Posted by Janicholson on March 31, 2010 at 17:50:50 from (64.61.211.105):
In Reply to: amp meter question posted by charlie M on March 31, 2010 at 17:14:08:
A marginal voltage regulator will be erratic like that. A loose connection can also be intermittent. If you have a different VR, try it to see if it helps. A bad armature could do it, as could weak brush springs or worn brushes, but my guess is VR. Jim
