Re: plowing advice needed
Posted by haas on March 31, 2010 at 18:19:37 from (75.254.86.75):
In Reply to: plowing advice needed posted by RJV on March 30, 2010 at 21:58:00:
Maybe you have the plow set to take too much land. Try moving the plow out a hole or two in the drawbar. If you are already at the outermost hole, you may need to set the wheel in a couple of inches. Also, if you are plowing sod, you need the coulter for the plow. If you don't have one, it won't do the best in sod.
