706D rear pump assembly
Posted by Michael Johns on March 31, 2010 at 18:37:13 from (75.38.59.26):
I removed the rear pump cover in order to find a shifter bushing from the range transmission shifter which fell during removal. still haven"t located it, but are there any tricks to re-assembly, It appears that someone used silicone to hold one of the flange o-rings in place which deformed it somewhat. The orfice hole in the flange is offset, figure may be a sealing problem somewhat, I suspect there may be a problem during re-assembly. I need to locate the bushing; been probing with a flashlight, mirror and magnet but no luck yet, I heard it fall, any experience greatly appreciated.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
