Re: Farmall 400 power steering problem
Posted by Nebraska Kirk on April 01, 2010 at 10:17:08 from (207.91.4.224):
In Reply to: Farmall 400 power steering problem posted by Nebraska Kirk on March 31, 2010 at 15:27:46:
The reason I said I did not think the problem was with the flow divider valve was because I swapped the valve with one off another Farmall 400. I got the second 400 all put back together yesterday afternoon and started it up and the power steering on it worked just as it should. I assumed that if the valve did not work on the one 400, it would not work on the second 400. Well, I was wrong!! This morning I got the rest of the stuff attached and hooked up on first 400, started it up and the power steering now works as it should!!
