Re: flywheel question
Posted by rustcollector on April 01, 2010 at 14:54:32 from (130.18.53.203):
In Reply to: flywheel question posted by jerry hakenwerth on April 01, 2010 at 06:41:05:
Jerry,
Turn the crank to where the dowl pin is in the top of the crankshaft flange. Then hang the flywheel on it to get the bolts started. I sometimes use a 1" X 4" or prybar to move the flywheel side to side and to make a sling to raise and hold it into the hole. Trick is to support so that it cannot fall.
