Re: MF Grain drill
Posted by STRAHL on April 01, 2010 at 20:07:37 from (207.69.139.159):
In Reply to: MF Grain drill posted by STRAHL on April 01, 2010 at 12:13:29:
I know how much to put per acre, my problem is the op. manual does not cover the adjustment for the small seed hopper mounted on front. It has an adjustment for quarts per acre, 0-20. This is an MF drill 9x7.
