Re: Farmall H changing mag to distributor
Posted by rustyfarmall on April 02, 2010 at 05:56:40 from (209.152.78.140):
In Reply to: Farmall H changing mag to distributor posted by Tom Fleming on April 02, 2010 at 01:30:51:
Tom Fleming said: (quoted from post at 01:30:51 04/02/10) I mean no disrepect, but why do you believe that a distributor is better than a magneto?
I actually prefer a mag. You can still start your tractor with a dead battery. Better starting in cold weather (if that is a factor for you).
Distributor's are a bit simpler (easier to work on), less moving parts, but functionally, I still think magneto's are better over all. Neither option works well without good points, plugs, wires, and condensor AND the correct timing.
If you want my opinion, put the mag back on and be happy! The best starting tractor I have is a 1938 F-20 with a F-4 mag.
A distributor will give more spark advance, resulting in more power and fuel efficiency.
