Re: Need a expert on motor oil. Which brand?
Posted by Pat-CT on April 02, 2010 at 07:06:25 from (137.36.225.229):
In Reply to: Need a expert on motor oil. Which brand? posted by Larry B 1486 on April 01, 2010 at 17:42:59:
Lucas is a great product, but it should be used in conjunction with good oil. Also if you were to really get into this you should run the tractor for a whole oil change period and then send the oil out to be tested. That way you can see how your engines doing and see how the oil is doing at the end of your oil change between the two brands. I think Rotella is the best oil for diesel engines but then that can be just a personal opinon also. This is one of those questions that you may get 10 diffrent answers.
However. You usually get what you pay for and that 22$ is alot cheaper then an engine overhaul. And oil is pretty much the life blood of an engine and is something that alot of people look over
