Re: IH 340U Hydraulics weak bucket lift factory loader
Posted by Janicholson on April 02, 2010 at 11:15:35 from (199.17.6.222):
In Reply to: IH 340U Hydraulics weak bucket lift factory loader posted by Johneich on April 02, 2010 at 08:40:24:
several possible realities:
restricted pump intake
Bypassing pump (worn out)
Internal hose failure (flap of rubber blocking hose inside)
Pressure regulator stuck open
Quick disconnect coupling not seated, or not the correct male end
Valve or link to valve worn not moving the spool far enough
A flow rater will tell the story! Jim
