Re: Re: Re: truckload picture
Posted by Wardner on May 25, 2000 at 11:42:07 from (63.23.216.66):
In Reply to: Re: Re: truckload picture posted by BobinIL on May 25, 2000 at 06:38:17:
All the sheet metal is the same between the IH and Farmall 560 and 660 with the exception of the verticle panels that cover the sides of the radiator. The 660 has a spliced on piece at the bottom that is about 3 inches high. The grills are the same as well. A cast iron spacer fills the 3 inch space. The radiator is taller to accomodate the higher output engine. The increased output comes from the injector pump that is governed to 2400 rpm. The only other difference between these tractors is the planetary wheel hubs and axel housings. All the rear sheet metal on the standard tread 560 and 660 is the same.
Post A Followup
: Re: Re: Re: Re: truckload picture
