Re: removing cylinder sleeves
Posted by Showcrop on April 02, 2010 at 17:02:39 from (75.67.231.80):
In Reply to: removing cylinder sleeves posted by Todd99 on April 02, 2010 at 14:32:48:
Yes you can buy them or you can make one out of some heavy steel and some fine threaded rod. The amount of pull that you need can vary a whole lot. I started out with heavy plate top and bottom, with some spacers on the top to hold the top plate up off the deck to give the sleeve some room to come up. On the bottom, once you get it freed up you need a disc that will follow the sleeve up through the bore.
