Re: IH 340U Hydraulics weak bucket lift factory loader
Posted by bc on April 02, 2010 at 22:22:22 from (68.92.139.215):
In Reply to: Re: IH 340U Hydraulics weak bucket lift factory loader posted by Johneich on April 02, 2010 at 12:29:50:
You would probably have to go to a dealer to find a flow rater. All the couplings, valve, and guage can cost some bucks just to do a pressure test. If the rest works, I'd look to the piston in the valve sticking, a cylinder piston leaking by, or a problem with a hose/fitting.
As I recall, the valve setups on some have a pressure relief valve in them that could be plugged and leaking by. Look for any hex head cap that looks like a bolt head on the valve assembly. Most likely a spring and ball or one piece relief valve. IH is good for putting them on every single thing. Those assemblies with 3 valves together would probably have one for each valve with an internal passage to the return.
