Re: 49 Cub Timein'
Posted by El Toro on April 03, 2010 at 04:46:08 from (74.103.74.58):
In Reply to: Re: 49 Cub Timein' posted by Wild Bill Caldwell on April 02, 2010 at 14:29:44:
If you have fire you need to check to see if the distributor or mag is in time with No1 piston by removing No1 sparkplug and bring that piston to TDC on the compression stroke. Then see where your rotor is pointing. If its at the the No1 plug tower your distributor or mag is in time.
Hold your hand over the throat of the carburetor and have someone make an attempt to start the engine. If there's very little suction means your intake manifold vacuum is low. Good manifold vacuum is required to suck that fuel into the engine. Low vacuum could be
caused by worn cylinders, rings stuck or valves not seating. Could be a leaky intake manifold. Hal
