Re: F10 loader gpm requirements
Posted by Janicholson on April 03, 2010 at 07:12:54 from (64.61.211.108):
In Reply to: F10 loader gpm requirements posted by Madalien on April 03, 2010 at 06:57:09:
Well you have some limitations:
The Liftall is about 5GPM so it will be slow.
Double that and it goes twice as fast.
The IH front (distributor drive mounted) pumps have 1200psi, but not much more flow, maybe 7GPM, I cant remember. The 1950 will need a front cover and heavier (late model gears) to accommodate that pump. M&W made a pump that fits the housing, but you still need the gears to reliably drive it without breaking the cam gear. The M&W Pumps are also rare and expensive and used, as well as not having either high pressure or volume.
A belt driven pump will need a good 5/8 wide V belt, or "gilmer" cog (like a timing belt) belt to handle higher pressure higher capacity. A PTO driven pump (or belt pulley) will do both the pressure and be able to put out 12 or more GPM. but not Live.
Good luck, Jim
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
