If you are unsure of the tractor"s history, you"d best measure the bore of the sleeve, the bore of the block with sleeve removed, and the piston diameter. Who knows what a previous owner could have modified or goofed up already? Putting H sleeves into a block modified for Super H parts would be catastrophic if assembled and ran. When measuring, you may find the wrong combination of parts in there if someone was really sloppy in their work or plain stupid. by the way, you never replace just the sleeves or pistons--they are a package deal. Not that it hasn"t been done or a rare situation might warrant one and not the other. Usually a worn engine is renewed with piston and sleeve assemblies. Sometimes a new set of rings is installed in the old piston and sleeve. But usually when these engines are torn down, they need new everything because of the wear or damage.
When you have it apart, fix it right so you never have to have it apart til it"s worn out and old again. Again, measure everything if you aren"t sure. Measure if you think you are :)
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
