Re: Updating Farmall H
Posted by rustyfarmall on April 03, 2010 at 13:35:14 from (209.152.78.140):
In Reply to: Updating Farmall H posted by Bob And on April 02, 2010 at 19:35:59:
Bob And said: (quoted from post at 19:35:59 04/02/10) Thanks Andrew. He has a loader on it and uses it on an acreage to plow snow, cut wood, etc. Kind of a nice tractor, power steering, wide front end, live hydraulics, etc. Just uses a lot of oil! I'll pull the pan tomorrow and see what the cylinders look like, but guess I'll have to install new sleeves. I can look down to the top of the pistons and see the top ring pretty easily!!! Thanks again. I'll stick with the 3 7/16's
If the engine is worn that badly, it is way down on power also, so doing a complete rebuild with the 3 7/16" sleeves and pistons will result in a whole bunch of increased power and performance.
