Ryan, The impulse should not be clicking or impulsing all the time even after it"s started and running if so set the idle up faster so it won"t be clicking all the time. Those are metal to metal parts and with it impulsing after it is started or all the time idling is going to wear the impulse out faster and just eventually ruin it. The impulse is just for spinning it over faster for a hotter starting spark after that it should throw out. If not you are just idling it too slow or impulse parts are worn out or got a weak impulse spring. Be sure to run non resistor spark plugs and metallic core wires with a magneto not resistor plugs or carbon core wire. Also make sure hasn"t got moisture in the mag. Mark"s Magneto in CT has a gasket set for the F4, F6 mags now too.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
