If it is the governor, here is pretty much a word for word description on how to adjust the governor from an IT Shop Manual.
" Adjust the carburetor; then with engine stopped, remove cover from the side of governor housing. Turn the governor screw (the upper one) until it just touches its stop (there should be no tension on governor spring). Place operator's hand lever in full speed position and adjust high idle speed screw (the lower one) until it just touches stop. To adjust governor to speeds which follow, start engine and place operator's hand lever in full speed position; turn high idle speed screw (the lower one)in to decrease speed or out to increase speed."
Hope this helps. I don't know much about adjusting carbs yet. If you need to refer to a diagram of the governor and its part numbers/names go to www.caseih.com and look under parts for it.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
