Re: 1952 Cub Carb
Posted by topsarg on April 04, 2010 at 05:37:14 from (69.8.42.122):
In Reply to: Re: 1952 Cub Carb posted by mkirsch on April 04, 2010 at 05:25:18:
Thanks for the quick response and help. Well yes I know when I did it. The halves were hard to seperate, so I figured I'd twist it a bit..that did it. Do you know if that part (tube) is available?
