Re: F10 loader gpm requirements
Posted by WOpp on April 04, 2010 at 11:04:26 from (75.229.0.181):
In Reply to: F10 loader gpm requirements posted by Madalien on April 03, 2010 at 06:57:09:
I converted my M to live hydraulic with mag drive pump and run it for many years feeding cattle every day. Mag pumps putout 12 gal/m which is half of what the yellow farmhand pump putsout. You will find your loader operates faster because you not going in and out of gear on your tractor to raise the loader. Everyone says you must change to heaVY TIMING GEARS and a diferent front cover. I never did and had no problems even with temps as low as -45 in NDak. I recomend you find a mag pump and enjoy your much improved tractor loader combination. You will never go back.
