Re: swap 560 engine?
Posted by mkirsch on April 04, 2010 at 13:40:20 from (67.253.216.24):
In Reply to: swap 560 engine? posted by gregk on April 04, 2010 at 08:02:25:
The simplest thing to do is split both tractors at the bell housing, and connect the good front end to the good rear end. They will bolt right together.
