Re: 560 stuck in gear
Posted by CGtractor on April 04, 2010 at 16:04:29 from (69.50.45.188):
In Reply to: 560 stuck in gear posted by Pete D on April 03, 2010 at 15:23:38:
Just repaired this same problem on my 560. Took 15 minutes. Well worth the time to fix it as it will happen again! Fifth gear is usually the one it gets stuck in because the travel on shift rails is less leaving a bigger hole for shifter tang to slip out of.
