Re: Farmall B 12v conversion questions???
Posted by Red Dave on April 04, 2010 at 16:39:51 from (174.59.227.184):
In Reply to: Farmall B 12v conversion questions??? posted by Seth Boyer on April 04, 2010 at 16:05:46:
Yes, changing to a 12 volt regulator will make it put out 12 volts. But it will not put out any more total energy (wattage).
If your maximum generator output at 6 volts was 20 amps (just to pick a number), it will be half that, or 10 amps at 12 volts. Double the volts at half the amps equals the same watts as original.
It will do 12 volts, but it can never put out nearly as much power as even a small 12 volt alternator.
But, if it still has a magneto, and all you need is to charge the battery for starting, it may well be enough for your needs.
Whether that is acceptable or not is up to you.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
