Re: governor
Posted by Janicholson on April 04, 2010 at 16:40:08 from (64.61.211.195):
In Reply to: governor posted by Jimmy in TN on April 04, 2010 at 14:33:28:
The main bearing (near the gear is a common wear point. as are the places where the control and throttle shafts enter and leave. If the main bearing is loose, binding can occur. If the shafts are loose, they will bind in the housing, or rub against things. Best of luck. A repair manual with specifications may be the next step, unless others can help with slow response to lever movement, and the power response to load being poor (if I remember) Jim
