Re: 560 stuck in gear
Posted by Janicholson on April 04, 2010 at 16:48:42 from (64.61.211.195):
In Reply to: Re: 560 stuck in gear posted by Al L. in Wisc. on April 04, 2010 at 09:49:54:
There are far more linkage components in that trans, (and outside it as well)
The linkage must be correct and small ball joints and pivot points wear free for it to begin to operate. Roll pins and worn pin holes can also be the problem. Start with the external issues, under the sheet metal, and proceed inward and down. A worst case is broken or damaged forks or internal linkage, but it happens. The Tractor Vet may ad to this to explain the internal issues. Jim
