Re: Touch Control problems after replacing o-rings
Posted by ScottyHOMEy on April 04, 2010 at 16:55:30 from (70.105.249.174):
In Reply to: Touch Control problems after replacing o-rings posted by couv on April 04, 2010 at 16:27:43:
It may just need bleeding out. All I'd add to Andrew's advice for that as a first solution, is to remove the fill plug while cycling it back and forth. If the problem persists, come on back and we'll troubleshoot it.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
