Re: 11 inch front wheel for an H?
Posted by mkirsch on April 04, 2010 at 17:46:44 from (67.253.216.24):
In Reply to: 11 inch front wheel for an H? posted by Rollie NE PA on April 04, 2010 at 17:26:12:
Depends on what you're measuring...
You could put 11.2x38 tires on the rear.
You can get an 11" wide drop center rim that will fit the H.
This post was edited by mkirsch at 17:47:39 04/04/10.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
