Re: Timein' CUB continuein' SAGA
Posted by gene on April 04, 2010 at 18:26:46 from (66.43.40.73):
In Reply to: Timein' CUB continuein' SAGA posted by Wild Bill Caldwell on April 04, 2010 at 17:16:09:
Your procedure sounds correct.
Check you pulley, some have two timing marks. The first mark is the advance and the second mark to reach the pointer is the TDC mark.
The two revolutions back to the TDC mark then time the magneto.
