Re: Timein' CUB continuein' SAGA
Posted by El Toro on April 05, 2010 at 04:26:37 from (74.103.74.58):
In Reply to: Timein' CUB continuein' SAGA posted by Wild Bill Caldwell on April 04, 2010 at 17:16:09:
You need to pull No1 plug and bring No1 piston to TDC on the compression stroke. Hold your thumb over the plug hole while someone hand cranks the engine until you feel pressure against your thumb. Have them keep cranking the engine while you keep your thumb over the plug hole until the pressure stops, then see if your timing marks are aligned. If they are see where the rotor is pointing on the mag. If its not at No1 plug tower you need to pull the mag and rotate the rotor to No1. Should be in the 1 & 2 o'clock area. Hal
2-1
4-3
