Re: M belt pulley seals
Posted by Dave47M on April 05, 2010 at 04:57:09 from (74.182.236.25):
In Reply to: Re: M belt pulley seals posted by wayne in mn on April 04, 2010 at 19:19:26:
wayne, thanks for your long reply, it is much better than the paragraph in the I&T service manual that says disassembly is apparent after studying their picture. Then I checked the archives here and did not find much either. I have tried to remove the pulley end cap but it was offering quite a bit of resistance and I have already broken one cast housing from applying a little more force rather than asking first so I do appreciate your help.
